Shot Transition not so soft at DVinfo.net
Old March 4th, 2008, 02:22 PM   #1
Is there a way to make the transition smoother?
For instance when either zooming in or out, I have the Transition Curve set to Soft Trans, Time/Speed set to Time, the Trans Time set to 6, Speed set to 10.
The zoom starts out slow, gets to a certain point and then there is an abrupt acceleration, gets to another point, then an abrupt deceleration.
It doesn’t seem to matter what speed/time is set. I was wondering whether the transition curve could be changed, unless you guys know of anything else.
Regards,
Simon
Simon Frances is offline   Reply With Quote
Old March 5th, 2008, 06:01 AM   #2
Have you tried slowing down the zoom settings in the main camera menu for both Low and High?
Keith Malone is offline   Reply With Quote
Old March 5th, 2008, 03:57 PM   #3
I noticed this too. There seem to be sweet spots for shot transition. Some combinations of speed and zoom are very smooth, others are clunky.
http://www.markoconnell.org
Mark OConnell is offline   Reply With Quote
Old March 5th, 2008, 04:04 PM   #4
I never noticed this with the FX1.
Michael
Michael Mann is offline   Reply With Quote
Old March 5th, 2008, 04:16 PM   #5
I also notice this and have not found a smooth one yet,
Paul Cronin
www.paulcroninstudios.com
Old March 23rd, 2008, 08:26 AM   #6
Same thing happened with me. Only I tried a focus transition. Choppy as ever. This really sucks
PMW-EX1 and Letus Extreme user
www.oyvindstokkan.no
Oyvind Stokkan is offline   Reply With Quote
Old March 23rd, 2008, 03:09 PM   #7
I agree - completely worthless - not smooth at all especially the zoom.
Greg Voevodsky is offline   Reply With Quote
Old March 25th, 2008, 12:56 PM   #8
I also agree, the zoom is significantly more noticeable whether set to speed or time. Another firmware recommendation!
Premier Pro CS5, Sony PMW-EX1, Miller Solo DS20 tripod
Steve Sykes is offline   Reply With Quote
Old March 27th, 2008, 03:04 AM   #9
With my EX shot transition with zooming is ok - not perfect but ok. But the "transition" with focus works much too fast: not even a part of a second and it's done (just 2-3 frames). Is this normal? I thought I could get smooth focus transitions?
Rainer Mann is offline   Reply With Quote
Old March 27th, 2008, 04:50 AM   #10
Have you set the transition to 'time' not 'speed'? 'Speed' is designed for the transitions using the zoom and 'time' is mainly designed for focus transitions.
If this is not the reason then it seems that there may be a varying number of problems with this setting for different cameras again, hopefully not!
Old March 28th, 2008, 03:53 AM   #11
Thank you, Steve!
Problem solved :-)
