TA100 Compatibility at DVinfo.net
Old November 4th, 2004, 12:44 PM   #1
TA100 Compatibility
Is the TA100 compatible with bogen heads, specifically the 516?
It looks quite large, but maybe I'm missing something.
Also, if anyone has any pictures of it actually attached to an XL2, attached to a tripod, that would be great.
Thanks.
Joel Guy is offline   Reply With Quote
Old November 4th, 2004, 06:49 PM   #2
Yes, it is compatable with a Bogen, or any tripod with a quick release plate.
www.digitalfx.tv
Greg Milneck is offline   Reply With Quote
Old November 4th, 2004, 09:20 PM   #3
Joel, I just bought both the TA100 and 516 head and it works great.
Cheers
I'll try to post some pics tomorrow...
Alexis
Alexis Vazquez is offline   Reply With Quote
Old November 5th, 2004, 07:11 AM   #4
Excellent. Thanks!
Old November 5th, 2004, 09:24 AM   #5
Here the links for some TA100-516 pics
http://www.audiovisuallab.com/xl2/ta100516-01.gif
http://www.audiovisuallab.com/xl2/ta100516-02.gif
http://www.audiovisuallab.com/xl2/ta100516-03.gif
http://www.audiovisuallab.com/xl2/ta100516-04.gif
http://www.audiovisuallab.com/xl2/ta100516-05.gif
Somebody once said that its not comfortable for shoulder....well not if you use the quick release from thr TA100 instead of the head. I found it more easy to release and mount than the bogen quick release, but thats just my opinion... I hope it helps you...
The pics was taken witha Panny 3ccd 120...not bad for a cheap cam.
Old November 5th, 2004, 09:53 AM   #6
Thanks Alexis! That's interesting, so it just fits over the entire head. It looks quite sturdy. I think I will have to get one.
Thanks again.
Old November 5th, 2004, 10:44 AM   #7
Will it work with the 501?
Josh Caldwell is offline   Reply With Quote
Old November 6th, 2004, 06:46 AM   #8
I have a bogen/manfrotto 505 head. I've been using the plate that came with the 505, which screws into the bottom of the xl2. It's pretty sturdy ( although it is only one bolt comared to the 4 screws on the ta100), but has to be removed if I want to use my monopod instead ( which has it's own mounting bracket).
Would there be a benefit in using the ta 100?
Bruce yarock
Bruce S. Yarock is offline   Reply With Quote
Old November 8th, 2004, 12:12 PM   #9
I have just one more question: How does the TA100 attach the the tripod? I understand how the camera attaches to the TA100, but cannot see in any of the pictures if the TA100 itself attaches to the tripod, in place of the quick release plate, or if it attaches to the quick release plate, which then slides onto the tripod.
This is important to me because I'm missing the release plate for my tripod, and would like to not to have to buy another.
Old November 8th, 2004, 07:34 PM   #10
well, unfortunatly it attaches to the quick release plate
www.digitalfx.tv
Old December 18th, 2006, 03:02 PM   #11
Is this TA100 Tripod Adapter made of plastic?
If so, is this setup super steady once you slide it on to the included plate? I am worried to have invested in a 529 Manfrotto Head and be disappointed with a loose quick release adapter.
What has anyone experienced?
Thanks.
Daniel Woltosz is offline   Reply With Quote
Old December 18th, 2006, 03:10 PM   #12
Josh,
I'm sure it would fit, but I would not use it if I were you. The 501 has no counter balance springs and anything that gets the camera up higher is just going to compound your weight problems when not level. It is going to want to fall forward or back even more.
JMHO
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old December 18th, 2006, 04:57 PM   #13
I resurrected this post to ask if the TA100 is quality
Pastic or metal? Looks plastic. Using this quick release plate on a quality head, will I end up with a loose mount because of play due to wear?
Thanks.
Old December 18th, 2006, 06:01 PM   #14
Images: 1
Thanks.
It's all metal construction on both pieces. There is a smaller piece that mounts to the bottom of the XL2 with 4 screws. The other piece is attached to the plate from the tripod that would normally be directly attached to the camera. To remove the camera from the tripod, you pull outward on the red release lever which moves a lock pin back and into a latched open position. When you slide the camera back onto the plate with a forward motion, it trips the latch and the locking pin moves into position making for a very secure mount.
I would have to humbly disagree with Mike T. on this one. I had TA-100's for both of my XL2's and I feel the 4 screw mount makes for a better mechanical coupling to the camera than the single 3/8 hole. But that's just my humble opinion.
This is the way the bigger cameras attach to tripods.
-gb-
Old December 18th, 2006, 08:59 PM   #15
I have the TA100 and IMHO I think that it is much better than just using the quick release on my 501 head. One of the main reasons I think this is that if you leave the quick release plate from the 501 head on the bottom of the camera, and take the camera off the tripod, you really can't set the camera down. The screws on the quick release stick out too far and the camera seems like it will fall over easily, possibly damaging the eye-piece or the mic. But with the plate that comes with the TA100, the bottom is flat and allows the camera to be taken off the tripod, used in hand, and set down on a table to change tapes or whatever. So I think that alone gives the TA100 quite an advantage over the standard quick release plate.
Yes it raises the camera up a little and there is no counterbalance spring on the 501, but I haven't found that to be a problem. If you watch what you're doing, and lock the camera in place when you walk away from it (which you should do anyway) I think anyone would be fine with the combo.
As far as the TA100 connection getting loose overtime - I've been actively using mine for about 9 months and it's still very tight. Maybe someone that has used one for longer could comment about long term wear.
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply
