xl-2 lens compatability at DVinfo.net
Old September 15th, 2003, 07:35 PM   #1
xl-2
does anyone know if the lens for the xl-1 and xl-1s will be usable on the xl-2? i know they are moving to hd, but does that exclude the current lenses?
anyone have any predictions as to when it will be on the market?
jake rheinfrank
xl-1 mac g4 sony 866 desktop
student
Jake Rheinfrank is offline   Reply With Quote
Old September 15th, 2003, 08:07 PM   #2
Warden
Anyone that really knows is under a non-disclosure agreement and can't say. If I had to guess, I'd say it will be different.
Jeff Donald
Carpe Diem
Old September 15th, 2003, 08:45 PM   #3
Re: xl-2
<<<-- Originally posted by Jake Rheinfrank : i know they are moving to hd -->>>
How could you know that?...
Old September 15th, 2003, 08:58 PM   #4
hd
canon along with sony and jvc decided on the 'hdv' format and will work out the details by september, and most likly will be going with that for the xl-2 since they have yet to produce a hd camera to compete with other hd camera already out...
just do a search on google for hdv, they all just came out with a press release.
jake rheinfrank
student
Old January 25th, 2004, 12:36 PM   #5
Keep in mind that the per the documentation, the standard XL1 lens was designed to resolve 100 lines/mm at the center and 64 lines/mm at the corners. This is translated to at least ~600 video lines on a 1/3" CCD with 3x4 aspect ratio.
Will this be adequate for the next generation XL? Depends on what the next generation system needs in the way of a lens (sensor size and resolution). If the transition from the L2 to the XL series is any indication, the lens may not be a great choice if HD is planned.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
