Battery belt for Frezzi XL-1 light kit at DVinfo.net
Old February 24th, 2004, 08:50 PM   #1
I have the Frezzi MFKIC-XL1 50 watt dimmer light kit for my XL-1. I need to know who sells good battery belts a reasonable prices. Is Bescor a good brand. How big of belt do I really need? Would a 2 battery battery belt work for doing say wedding receptions. The Np-1 battery setup that came with this kit is a money pit joke. I bought 3 of the NP-1's at $100.00 a pop and now realize maybe a belt might be a good investment instead.
John Dimasi is offline   Reply With Quote
Old February 24th, 2004, 09:06 PM   #2
Retired DV Info Net Almunus
Bescor has a good name. I use an NRG battery belt which has been quite good. There are several capacities available. Mine is designed to allow continuous operation by way of patching a fresh belt into the power chain without shutting down. (Something I've never done.)
Old February 24th, 2004, 09:25 PM   #3
Warden
I too use a NRG belts. Zero problems and they have been used under very extreme conditions.
Jeff Donald
Carpe Diem
Old February 25th, 2004, 09:11 PM   #4
Any specific models of NRG that anyone could recommend?
Old February 25th, 2004, 10:49 PM   #5
John,
Frankly, just get the biggest, most expensive belt you can afford. I believe mine's a 97044-BL. If you're going to be in situations where you will have to rely heavily on this power source it makes no sense to skimp.
Old February 26th, 2004, 06:40 PM   #6
Ken,
The NRG belt model you named is 13.2 volts instead of the usual 12 volt belts I've seen. Can you use a 13.2 volt belt to power a 12 volt light without causing any harm to it?
Old February 26th, 2004, 09:00 PM   #7
Yes, no problem. The "12 volt" spec is actually just an industry nominal label. The actual voltage delivered to a device will normally vary over time.
Old February 26th, 2004, 09:02 PM   #8
Thanks again Ken for your help
Old February 27th, 2004, 03:26 AM   #9
you also might consider
the anton bauer kit for the xl1, although due to price you might just want to buy the plate new and batts and chargers off ebay or other place. It also adds a nice counterbalance to the camera for easier shooting....Ive got anton bauer belts and wouldnt reccommend them way to heavy for run and gun,(yeah I know they arent that heavy :) I use them to power lowel pros instead.
M
milking the celebrity criminal trials thank god for the freaks
Michel Brewer is offline   Reply
