black bar under picture... at DVinfo.net
Old December 23rd, 2002, 10:23 AM   #1
i used to browse through threads of users complaining about black bars appearing under the pictures. It didn't concern me either until I reinstalled the computer or sent my camera for a checkup to canon. So you recon I send the camera back? Did you all come up with a definite reason and/or solution to this?
Thanks in advance.
Takeshi
Takeshi Fukushima is offline   Reply With Quote
Old December 23rd, 2002, 10:32 AM   #2
This flaw is inherent to the XL1S CCD block. (The XL1 has black bars on the left and right sides.) You will likely not gain anything by sending your camera back. I was pretty upset when I first realized it too--still am! As you probably remember, DVInfo.net Community members discussed this issue extensively last spring/summer. See http://www.dvinfo.net/conf/showthrea...&threadid=1482 and http://www.dvinfo.net/conf/showthrea...&threadid=1743.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old December 23rd, 2002, 11:08 AM   #3
Some users may consider this issue to be a flaw, but Canon does not; there is no fix or repair to be had and many other camcorder models exhibit this "feature" as well (such as the Sony VX1000). Sending the camera in to Canon service will not change anything as there is no modification available.
The black bars are at the edges of the frame and will not appear in the TV-safe area of any video monitor or television. You may see them on a computer screen, but never on a video monitor. If you're doing video for web delivery or any application which is viewed on a computer screen, Canon recommends cropping the image to the standard TV-safe area.
Although the XL1 and XL1S have this issue, the GL2 does not. Hope this helps,
Old December 23rd, 2002, 04:55 PM   #4
Me too!
I was just about to post on the board about this very same issue. It's said if the heads ever need aligning, it's within the first few weeks/months of use to fine-tune from the factory. I assumed I was one of the unfortunate individuals who would have had to send it in. But if nothing can be done about it, I'll just have to grit my teeth. It's quite upsetting, Canon's flagship camera having this annoying little glitch
My XL1s has a QF manufacturing stamp on it, so it's one of the newer manufactured cameras from this year, this 'feature' doesnt seem to have gone away :)
Andrew | Canon XL1s, ME66, Vinten Vision 3, GlideCam V16 (for sale!)
Andrew Petrie is offline   Reply With Quote
Old December 23rd, 2002, 06:17 PM   #5
Is the post about a black bar UNDER the picture, or at each side?
Old December 31st, 2002, 02:51 PM   #6
I don't think the bar issue is totally based on the camera.
Read this post:
http://www.dvinfo.net/conf/showthread.php?s=&postid=36292#post36292
justin
www.monsterrocket.com
Filmmaker | Cinematographer
Justin Chin is offline   Reply
