Shake / Earthquake effect at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old January 6th, 2009, 09:20 PM   #1
Shooting a music video and when the singer screams we want to make the entire video shake, an earthquake effect if you will. Any plugins or ways to go about doing this or just shake the camera?
Figured a programmable effect would be nicer since I could customize it and make sure it looks good.
Thanks.
I like cake.
Dustin Alcock is offline   Reply With Quote
Old January 7th, 2009, 10:00 AM   #2
Yeah I'm using a preset in After Effects right now, which I think is called quaker. I downloaded it online for free and it seems to be a combination of 3 effects. It's at home so I can't really help right now, but in the meantime you could probably find it easy enough online.
Aric Mannion is offline   Reply With Quote
Old January 7th, 2009, 11:04 AM   #3
You could get hold of a large surface-coated mirror, mount this to a very flimsy MiniDV tripod, rigidly attach a thin piece of fishing rod with a small weight on it. Pluck or strike the piece of fishing rod to set up a vibration.
Experiment with the frequency of the vibration for best vibration. Adjust this by lengthening or shortening the rod through a clamping mount or make the position of the weight adjustable along the rod and vary the weight until you get what you want.
The direction of the vibration will be more random if the rod is attached facing directly down or up. Aim the camera so as to image the subject via the surface-coated mirror which will shake when you pluck or strike the piece of fishing rod.
If your camera is itself lightweight, you could choose a flimsy tripod for your camera and mount the vibrating rod directly to it. This effect will start suddenly and fade away. It is not easy to start small and ramp the effect to its maximum. In some circumstances you might be able to reverse the playback of the shot.
Old January 7th, 2009, 12:12 PM   #4
Aric, yeah I searched and easily found it. Viewed the sample video and it's exactly what I'm looking for. Thanks!
Bob, creative. I'll see if I can get what I need out of the plug in first though, seems easier, haha. The stuff people come up with the create effects is something though, really opens your mind on doing weird things to get what you need.
I like cake.
Old January 7th, 2009, 10:37 PM   #5
Shake, rattle, and roll!
Hi dustin, i've shot the exact same sequence - singer singing and camera shaking - thankfully i was using a sony fx1 handheld on a relatively slow shutter speed. I added the shake manually (by jerking from the elbow) which allowed me perfect control of intensity and timing and the shutter speed gave a nice motion blur effect that no plugin could have given me! It worked like a charm :) remember, if you can do it in production then its still way better than in post. By the way, if you're on a pc then also check out proDAD and blueFX for plugin choices. Happy shaking!
Windows 7 Ultimate 64-bit // i7 2600K // 16GB RAM // ASUS P8P67 Board // NVIDIA GTX 470
Sony Vegas Pro 13 // Adobe Premiere Pro CC 2014 // http://vimeo.com/alijafri
Ali Jafri is offline   Reply With Quote
Old October 30th, 2009, 02:34 PM   #6
Does anyone know a way to achieve this effect in Motion?
"Get Er Done!!!"
G. Lee Gordon is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
