Continuous reorient 360 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > 360 Panoramic / Spherical + AR & VR
Take a look *around.*
Old April 22nd, 2017, 03:48 PM   #1
I have launched a Gear 360 up on a balloon which generated some good footage but watching it makes everyone feel sick. Is there a way of continuously reorienting the video so the view does not spin? Thanks to the built in gyro, the horizon is always level, just need to correct the spinning.
Thanks.
Tim Squires is offline   Reply With Quote
Old April 23rd, 2017, 09:19 AM   #2
Re: Continuous reorient 360
Perhaps use a compass or inertia sensor and control with a gimbal motor?
Old April 23rd, 2017, 01:35 PM   #3
Good idea, thanks. I have gimbals which could possibly be adapted to mount the Gear 360 but it is a totally different balance than the other cameras so will take quite a bit of work. I was hoping for something in post-processing that would let me continuously control the orientation. Something like the Dashwood 360 reorient tool but instead of setting the orientation for a clip, it can be moved around.
Old April 27th, 2017, 03:15 PM   #4
with adobe premiere (starting premiere pro cc2015.3) you can move video, so you would compensate for the rotation.
Old July 26th, 2017, 04:26 AM   #5
Hi Tim
I have been recently experimenting with 360/VR post-production workflows and there is indeed a possible solution to this issue, which although not perfect, would certainly help ease the spinning effect. There is a "Rotate Sphere" effect in the Mettle Skybox suite plugin for Premiere that allows you to rotate the Y axis (i.e. pan it) but more importantly, it also allows you to keyframe it, meaning that you can animate the rotation over time.
Interestingly, the Mettle Skybox Suite has been acquired by Adobe, and will be integrated into Creative Cloud by end of 2017 so, in other words, will soon be free. But in the meantime, if you already have Adobe Premiere all you need to do is drop them an email (details on the Mettle website) and they will send you the plugin now for free. From my initial experience, the plugin works very well.
If you don't have Premiere then I'd be happy to take a look at the footage and use the "Rotate Sphere" effect and see what can be achieved. Just let me know.
Canon C300 Mk2 x 2, Rotolight Anova Pro and Neos, Ronin Gimbal, Phantom 4 Pro UAV www.danthecameraman.co.uk
Dan Parkes is offline   Reply With Quote
Old July 26th, 2017, 05:17 AM   #6
Add a big vane. Like a weather vane to keep it pointing into the wind💨
Donald McPherson is offline   Reply With Quote
Old July 26th, 2017, 06:31 AM   #7
The balloon is moving with the wind, so from the balloon's perspective there is no wind and thus a rudder would not help. The one exception occurs when the balloon passes through an inversion layer and an apparent wind would exist while the balloon accelerates to the wind speed in the layer.
Jim Michael is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > 360 Panoramic / Spherical + AR & VR
