Using Dashwood 3DA1 app with a Sony TD300
I'm hoping Tim Dashwood or anyone else who has computed the offset for a 60mm IA (3DA1) & 42mm (Sony TD300) can chime in to guess how to use this workhorse app with the smaller IA Sony TD300 - if possible.
The problem with using most (if not all) of the 3D calculation apps with a fixed IA camera is that they normally compute the stereo base by data entry of other measurable variables and then give you the IA setting. I need to do the opposite. Also wondering if anyone knows of a 3D calculation app that does do this. |
Re: Using Dashwood 3DA1 app with a Sony TD300
Hi Bruce,
I just put the finishing touches on the Z10000 Calc app and will be submitting to the App Store in the next day or so and then I will finish the TD300 Calc App. The nice thing about the TD300 is that you can simply set your maximum positive and negative parallax and let the warning system alert you to the areas of the image that exceed those values, so I'm not sure the app will provide an added benefit while shooting. |
Great news Tim. I'm heading off to Australia next month to shoot 3D with both the TD300 and Z10000 so I'll be looking fwd to getting both apps.
Can you post again when they are available for download? |
Tim, is your TD300 calculator available yet??
Not yet. We're cooking up something big for Toolbox LE next week and then we will be full force back into the TD300 Calc project.
Thanks for the reply so quickly Tim. I'm using the TD300 for the next two weeks so I was anxious to give your app a go with it, but the viewfinder and menus are pretty specific and using anaglyph VF mode seems to be the best way to quickly spot-check divergences etc.
The TD300 has a built-in visual warning system that you can set to trigger at a custom positive and negative parallax. It's somewhere in the menus. It's my favorite implementation of that feature in all of the pro 3D cameras.
All in all a very easy to use camera and much better min focal distance to work with than the 3DA1. |
Tim, is the Z10k Calc app available yet?
Thanks Neil |
