HV20 - No LANC? No problem. at DVinfo.net
Old May 9th, 2007, 05:25 PM   #1
Someone else came up with this idea first ... http://www.dvinfo.net/conf/showthread.php?t=16934. Too bad the pictures are gone, so I had to use my imagination.
Seems to work okay. Used the wireless controller plus a toslink cable to make a mountable controller. The remote is upside down so my palm doesn't get in the way. The zoom and start/stop buttons are the critical controls anyway. Now if only the controller had a joystick control ....
Build details at http://yousillyman.blogspot.com/2007...ontroller.html
DIY, 35mm, HV20:
http://www.primitivebuteffective.net
Mike Dulay is offline   Reply With Quote
Old May 9th, 2007, 06:02 PM   #2
Had the same idea but did not know if it was going to work with fiber.. thx for the share :)
How thick is the fiber?
Johan Bunis is offline   Reply With Quote
Old May 9th, 2007, 06:17 PM   #3
Johan
The toslink cable is pretty standard. Its about 5mm wide including the insulation, not sure how thick the glass strand actually is. The terminus is about 1mm wide by eye.
If you don't have a toslink cable lying around (mine was $3 plus $6 shipping from Amazon ;-) you might be able to pull it off with those toys/ornaments with the light filament.
DIY, 35mm, HV20:
Old May 9th, 2007, 07:29 PM   #4
Sweet! Very resourceful.
Peter J Alessandria is offline   Reply With Quote
Old May 10th, 2007, 07:23 AM   #5
It works very well, but I found the Toslink a bit too stiff, I'd much prefer a coiled wire.
Once I finally get my HV20, I'm going to get a cheap universal remote & learn the zoom & start/stop codes from the Canon. I'll then desolder the IR LED & replace it with a stick-on IR transmitter, these can be had for $6 or less. Add a nice coiled wire, it'll look very pro. ;)
P.S. I have a question: does the Canon remote have focus control? Kind of hard to see from the Canon manual. Also, does it have a variable zoom speed, or does the speed have to be set on the camera first? I'm thinking of different possibilities here if I get a learning remote with a joystick/hat control on it. Varizoom, watch out! :D
Roman Shafro is offline   Reply With Quote
Old May 10th, 2007, 09:56 AM   #6
Roman,
There are not focus buttons on the remote. I haven't read the manual that thoroughly either. As for the zoom, the default is variable mode. There are three other fixed zoom speed settings for more precise control but you need to pick one from the camera.
I hope you find a way to control the rest of the settings by remote. I'd love to see how you can make this work!
DIY, 35mm, HV20:
Old May 11th, 2007, 06:15 AM   #7
Originally Posted by Mike Dulay View Post
Roman,
Thanks for the info. This project is No.95 on my list, but I'll get to try it, eventually. I've yet to get the HV20.
Love your blog site, BTW.
Old May 11th, 2007, 07:24 AM   #8
Excellent, Mike -- quite resourceful. Sure appreciate you sharing this with us! Thanks a bunch,
Old December 13th, 2008, 03:18 PM   #9
Presets for zoom stops?
Roman,
Hello Mike,
I'm looking to preset the HV-30 zoom at three settings, besides all or none. Do you have any ideas how i might do this?
Cheers,
Christo
Christo Aaron is offline   Reply With Quote
Old December 13th, 2008, 07:20 PM   #10
Go Cycle
DELETED. Original POSTER duplicated the post in another thread
Lou Bruno
Lou Bruno is offline   Reply
