View Single Post
Old November 1st, 2007, 12:49 PM   #15
Hans Ledel
Actually 13 Mbps isn't low. It's the best of all recording settings that Panasonic uses throughout their AVCHD line (the others being 9 Mbps and 6 Mbps). Remember, this camcorder is an addition to their AVCHD camcorder family, not a departure. That means you can't reasonably expect them to make a radical change to their established AVCHD recording bitrates.
The format spec allows up to 24 Mbps; most likely we'll see that in an AVC Intra codec on a later, higher-end Panasonic camcorder. For now, there's nothing wrong with 13 Mbps as the best recording setting for this and other Panasonic AVCHD camcorders. It's right in line with 15 Mbps on some HDD-based AVCHD camcorders and 12 Mbps on some disc-based AVCHD camcorders. Hope this helps,
Thanks Cris.
I must say Iīm a bit confused.
I thought that the codec was the same be it Sony or Pana or Canon but I guess itīs not.
So you canīt just compare the bitrates from different companys as I did?
Cheers
Hans
Remember, that English is my second language.
Hans Ledel is offline   Reply With Quote
