IF you're handy with a soldering iron, you can build your own at least to some extent - I've managed to reverse engineer SOME of the mysteries of the A/V jack. I'm trying to get time to revisit the thing and try a couple new twists so I've got EVERY secret unlocked before I "publish". I've got the LANC licked, and the s-vid outputs figured...
The audio I/O is a bit more problematic, and interacts with other inputs on the camera... From the service manual diagrams, Sony has all the different I/O ports (AIShoe, A/V jack, mic and headphone jacks) linked to some degree and re-configurable depending on what is plugged in where... the LANC interface was relatively easy to suss out... it's mapping all the other functions that's turned out to be a PITA...
