Z7U error? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old September 25th, 2008, 11:21 AM   #1
Z7U error?
Anyone know what "E:61:30" on the top right of the screen means? I had my memory recorder disconnected, turned the camera on with a DV tape and was setting up for a SD shoot and this error message was seen, when I powered down, hooked the memory unit back up and restarted the flashing E:61:30 disappeared and showed my actual tape meter.
Could not find anything online about this. I was thinking perhaps it was because I started it w/o the memory recorder on the camera and had it set up to use it previously?
Not a huge deal, I was just wondering if anyone knew what that error meant.
-Scott Caplan
Triad 3 Media, LLC
Scott Caplan is offline   Reply With Quote
Old September 25th, 2008, 05:13 PM   #2
Contact your sony service centre and inform them of the 5 digit code starting with E:
thats straight from the manual
Robert Bec is offline   Reply With Quote
Old September 26th, 2008, 07:52 AM   #3
The error code E6130 means: reset position detect error when stepper iris is initialized.
I guess you better contact your Sony dealer.
Ivan Snoeckx is offline   Reply With Quote
Old March 4th, 2010, 07:33 PM   #4
I have the same problem on my Z5, and the iris ring does not work at all!
Did you figure out what to do?
I am going to call Sony in the morning
Silas Barker is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
