EX/AVID Workflow
October 1st, 2008, 04:19 PM
Hi,
I have MC3.0 on Windows. I haven't figured everything out yet. But as I understand it, I should be exporting AAFs in Clip Browser 2, then importing those AAFs in MC3.0 (which point to MXF files placed in your AVID Media Files folders), then transcoding the XDCAM video files to DNxHD145 (virually no loss in quality) so that I can edit efficiently (without the jerkyness of GOP) and then output a quicktime reference (now possible since the video is DNxHD) to eventually make a DVD.
The problem is that if you transcode both video and audio to DNxHD145 (or to DV25 for example because you want to save space, take advantage of your SD MOJO, or not need HD for awhile) you lose the link to the XDCAMs in the Avid. The drag with this is you also lose link with the originals. In other words there is no such thing as batch transcoding as there is with importing or capturing.
Transcoding upon import would solve this I would think. You could import/transcode to DV25 then when you have your sequence you could import/transcode to DNxHD145 for final outputing. Will this be corrected in a future MC or have I got something mixed up?
Thank you
Richard Burman
Richard Burman
