Edit Wedding dvd Back Into Premiere - Page 2 at DVinfo.net
Old November 10th, 2008, 12:31 PM   #16
Oookay. Now it all makes sense. Sorry for the misunderstanding!
Black Label Films
www.blacklabelweddingfilms.com
Travis Cossel is offline   Reply With Quote
Old November 10th, 2008, 07:45 PM   #17
DVD to whatever format
I've done this SO many times that I've found the perfect combination of software.
Either you copy the .VOB files to your PC or use a software to do it for you. I would recommend DVD Decrypter
All you need to do here is click on the DVD -> Hard Drive icon and select the destination.
Then you use this great software called AVS Video Converter from AVS Media. You can basically import any video format type and export it to any other format of your choice. Why i find this software so powerfully is that you will not loose audio sinc going from .VOB file to .AVI, .MOV or .WMV. You can control the bit-rate, the aspect ration and you can batch convert, which is very usefully.
Hope this was helpful and let me know how it turns out.
Carl Wilky is offline   Reply With Quote
Old November 11th, 2008, 06:33 AM   #18
Thank you Carl for your input I will give that a go.
I thank you all for your input.
Anymore ideas please let me know.
Wayne
Wayne Greensill is offline   Reply
