I got a lens stuck on my SGpro... HELP! at DVinfo.net
Alternative Imaging Methods
Old November 11th, 2008, 10:06 AM   #1
So I got a Quantaray lens stuck on a Nikon mount... I was so sure that it would fit because it fits on my Nikon D50. I have taken the mount off and tried to twist as hard as possible to get it off but that has not worked! Any help would be appreciated, because I borrowed the lens and need to return it (without breaking it). Thanks in advance!
http://i176.photobucket.com/albums/w...SgproStuck.jpg
Chris/Final Cut Pro Certified/Apple is my life.
Canon XH-A1, SGpro
Chris Christensen is offline   Reply With Quote
Old November 11th, 2008, 10:55 AM   #2
Here is a link to a photo album with some pics of the inside of the the lens. I tried my best to get close but without a macro its tough ;) any help would be much appreciated!
everpresentchris/SGpro Mount - Photobucket - Video and Image Hosting
Canon XH-A1, SGpro
Old November 12th, 2008, 09:12 AM   #3
OK, It's obviously cross threaded itself some how. It happens.
You have three holes on the outer ring showing in your picture.
Lay a piece of cloth onto a block of hardwood and clamp it to a work bench or strong table.
Take 3 small PZ1 screws and going through each of the holes screw the entire assembly to the piece of wood.
This will now give you the firm resistance you'll need from the nikon mount to turn the lens out.
I've had a similar problem and this worked a treat.
Good luck.
Stuart Campbell is offline   Reply With Quote
Old November 12th, 2008, 02:43 PM   #4
Good luck.
Thanks for the help, although I unfortunately did not get to try your method, I got it off by taking a screwdriver and wedging it somehow! that was soooo weird!
Canon XH-A1, SGpro
Old November 12th, 2008, 03:45 PM   #5
Screwdriver, force, near the lens?
You must be very confident of your screwdriver forcing abilities!
Glad you managed to remove it successfully.
Old November 12th, 2008, 03:51 PM   #6
Hahaha yeah, I know, it was scary, but I was pushing away from the lens and figured i wouldn't be able to scratch it very easily ;) it was still kind of scary, but i was frustrated!
Canon XH-A1, SGpro
