Quicktime instead of Compressor at DVinfo.net
Final Cut Suite
Old November 15th, 2008, 02:37 PM   #1
After reading this on the Apple QuickTime site I have been able to produce small size nice quality from 720P Quicktime.
Apple - QuickTime - Tutorials - Creating Amazing Video Content with H.264
Are others using this option to render for their web sites?
Paul Cronin
www.paulcroninstudios.com
Old November 15th, 2008, 09:09 PM   #2
Yes, I have used Quicktime compressor for virtually all my work originated in DV25, 1080i HDV and 720p H.264/AVC (in MP4 wrapper) etc. and exported to DV stream, m2t MPEG-2, as well as various AppleTV, iPod/iPhone-compatible formats with varying specs with excellent results.
My only use for the stand-alone Compressor is when compressing files to SD DVD-ready MPEG-2 format for re-exporting to DVD Studio Pro.
However, for web contents you may need Adobe or Sorenson Squeez to compress to one of the Flash video formats as Quicktime does not seem to support Flash.
Wacharapong
Wacharapong Chiowanich is offline   Reply With Quote
Old November 16th, 2008, 04:59 AM   #3
I tend to use Quicktime rather than compressor and I have a flix plug in that gives flash option in the export list.
Old November 16th, 2008, 08:13 AM   #4
I use Quicktime most of the time because compressor is way too slow. When I do use compressor the stuff looks great.
Denise Wall is offline   Reply With Quote
Old November 16th, 2008, 12:06 PM   #5
Gary what fix plug do you use to create flash from Quicktime? How is the quality compared to Quicktime streaming? The Quicktime streaming are very small files which load quickly.
Paul Cronin
Old November 17th, 2008, 04:43 AM   #6
Compressor can be slow if it isn't set up to use all the processing cores. I am still relatively new to FCP, but I remember when I first got it I found that I had to go into Apple Qmaster and set it up. After that Compressor was much faster.
Simon Wyndham is offline   Reply With Quote
Old November 17th, 2008, 05:12 AM   #7
Yes - I'd be interested in knowing about the flash plug in. I use the H.264 codec (either exported from Quicktime or sent to compressor via h.264 LAN settings) and the results, considering the small file size, are impressive. In flash however, the clips fall apart at the seams - terrible degradation.
David Scattergood is offline   Reply With Quote
Old November 17th, 2008, 07:44 AM   #8
I am using the flix exporter:On2 Flix Exporter - Free software downloads and reviews - CNET Download.com
There is a free trial available.
I prefer the apple codecs but we have been having problems with them when uploaded to our streaming site.
The flix takes a long time to encode and the quality is not as good as apple desktop but at the moment we have to upload flash.
Old November 17th, 2008, 08:06 AM   #9
Simon that is a good point. When I switched to Mac last year I set up Compressor in Apple Qmaster. It is not the speed that had me look else were it is the files size for the web. Matching files size with picture quality I have found QuickTime is doing a better job. But for all other outputs I use Compressor.
Thanks Gary.
Paul Cronin
Paul Cronin is offline   Reply
