Solution for APE 3.0's large h.264 files! Quicktime Pro Needed! at DVinfo.net
Adobe Creative Suite
Old November 16th, 2008, 11:18 PM   #1
So, I've been editing footage from my XHA1 on Adobe Premiere Elements 3.0.
Here's the problem.
A 1 min 30 sec clip, compressed to h.264, comes out to 450+ mbs!!!
Now, I don't know if that's normal, but it's very high for me.
The solution:
Step 1:
Open the 720p or 1080i video with Quicktime Pro
http://i95.photobucket.com/albums/l1...mpression1.jpg
Step 2:
File>Export
http://i95.photobucket.com/albums/l1...mpression2.jpg
Step 3:
Change export setting to Movie to QuickTime Movie
and Click Options
http://i95.photobucket.com/albums/l1...mpression3.jpg
Step 4:
Click Video settings
http://i95.photobucket.com/albums/l1...mpression4.jpg
Step 5:
Set the Compression Type to H.264
Set you Quality to Medium or High
Set "Optimized for:" to "Download"
Click OK
http://i95.photobucket.com/albums/l1...mpression5.jpg
Step 6:
Go to Sound Settings
http://i95.photobucket.com/albums/l1...mpression6.jpg
Step 7:
Format to AAC
Click OK
http://i95.photobucket.com/albums/l1...mpression7.jpg
Step 8:
Press Ok and start the export
http://i95.photobucket.com/albums/l1...mpression8.jpg
Comparison:
Size
http://i95.photobucket.com/albums/l1...mpression9.jpg
Quality
http://i95.photobucket.com/albums/l1...pression10.jpg
Hope this helps!
Check out my blog at KevinSawicki.com
Kevin Sawicki is offline   Reply With Quote
Old November 16th, 2008, 11:43 PM   #2
All of these settings are available in adobe media encoder.....
Jon Sands is offline   Reply With Quote
Old November 17th, 2008, 07:40 PM   #3
In this step: http://i95.photobucket.com/albums/l1...mpression5.jpg
You leave the data rate set to automatic. I'm not high on that idea since I don't know what any transcoder will do with that. You're better off specifying both the data rate and whether you want constant or variable bit rate.
You might be able to tweak other settings to get the size where you want it, but bit rate is always the key parameter.
Tripp Woelfel is offline   Reply
