Cannot view Quicktime HDV on Windows at DVinfo.net
Final Cut Suite
Old November 18th, 2008, 11:17 AM   #1
Normally I shoot my JVC 110 + Firestore in M2T when I shoot HDV but on some projects I use Quicktime HDV when editorial is FCP. This time however I need to have access to clips for both FCP AND Adobe on a Windows XP system and I cannot find ANYTHING that will convert QT HDV or allow me to open the files.
All I get with Vegas or Premiere is audio.
Is there anything out there that will allow me to open QT HDV on Windows at all?
Help!
Jeff H in TX
Jeffery Haas is offline   Reply With Quote
Old November 18th, 2008, 12:53 PM   #2
Pardon me for stating the obvious but I assume you have tried Quicktime Pro for windows? Just checking because you didn't mention it.
Justin Ferar is offline   Reply With Quote
Old November 18th, 2008, 01:53 PM   #3
As stated above, try quicktime pro for windows. If not, then try to use FCP or Compressor to convert the files into something your Windows based NLE would be able to work with.
Louis Maddalena is offline   Reply With Quote
Old November 18th, 2008, 02:06 PM   #4
You cannot decode and view Quicktime HDV files on Windows or any Mac that doesn't already have Final Cut Studio installed. The HDV quicktime component is only installed with Final Cut Studio.
On a side note there is now a free ProRes422 Quicktime decoder available for Windows and Mac.
Tim Dashwood
Old November 18th, 2008, 04:50 PM   #5
Does the ProRes decoder have anything for me or is your above statement the final thud of disappointment?
Are you saying that I have to have the clips converted to something useable from FCP and that's the only choice? It will be a hassle but I can live with that if I have to.
PS: Yes, the very first thing I tried was opening the clips in Quicktime Pro for Windows, didn't work.
Old November 18th, 2008, 05:38 PM   #6
Jeffery
You can buy a decode only Quicktime Codec from Calibrated Software (XD Decode for Windows) that will let you view QuickTime HDV, XDCAM HD and XDCAM EX Movies (.MOV Files Only) in QuickTime Player and any other 3rd party applications that support QuickTime on your PC. .
Calibrated{Q} XD Decode
There's a free demo so you can check to see if its any good for your situation. Its a 80 bucks to buy ... we bought it for our Carbon Coder PC and have been very happy with it so far.
Cheers
Andy
Andy Mees is offline   Reply With Quote
Old November 18th, 2008, 09:16 PM   #7
Welp...I forgot that the Firestore also functions as a VTR, and I should have remembered this because that is what saved my butt the day a partner "smoked" the mainboard.
The DV-I/O port still worked and I was able to pull my clips off the device by "capturing" with it as if it was a VTR.
So here I am capturing all the material off the Firestore using it as a "playback" unit
and it's working fine. A PITA because it has to be recaptured but hey it works.
I'll give that codec you mentioned a look, but it has to be able to allow me to convert to another format in order to be useful.
Looks like I'll be going back to building that Hackintosh after all though.
