I'm not familiar with your issue. Wish I could help.
However, just to reaffirm your workflow:
1: Render to Mpeg 2 always using the DVDA template...do not use the generic Mpg settings.
2. Audio use ac3 as you are and do not render together at same time with video, always render separately. (You probably are, but just making sure)
If you make a movie that is to play on the DVDA menu, render that mpeg 2 DVDA template, but change custom settings to progressive.
Avoid the way you used to do it. Using AVIs means architect will have to re-render it...if you render as above it will go onto disc as is and will be high quality.
Good luck
