View Single Post
Old November 30th, 2008, 10:35 AM   #5
Tripp Woelfel
I've had a couple of Epson printers and have had good luck with them. Sounds like you got a pink one. I currently have the RX595 and beat it to death. After a year, it's still all good. It will print everything I want, plus it has a scanner. There are probably a number of Epson models with the same printer "engine". I don't have a CISS but I've read there are systems for a number of Epson printers. I paid US$150 for mine.
Printing on the DVD media is not an ink-intensive activity. I've read that you can give the disk printing surface a glossy look after printing by spraying a thin coat of urethane, but I've not done this.
As for DVD inserts, you'll want to use stock made using photographic paper. The difference compared to matte paper is quite large. This is also very ink intensive so a CISS will be valuable if you're doing any real quantity. Outsourcing may be more cost effective for what you're doing if you do larger runs. Nearly any copy shop should be able to do this for you as long as they have the paper stock. Being an yanqui, I cannot help you with a local resource.
Tripp Woelfel
