Final Cut won't open! at DVinfo.net
Final Cut Suite
Old December 1st, 2008, 02:41 PM   #1
Final cut wouldn't open, so I had to install the fcp update. Did that, and now I can open the program (by the way, also upgraded quicktime pro to 7.5.5). The only problem is that HD footage plays back with a stutter, and if i have rt set to safe, I get constant dropped frames. I play the same footage back on another identical macbook or in quicktime and have no problem.
Any clue as to what might be going on here? I had been editing with it the day before thanksgiving with no problems. I packed my laptop and drive up, drove to michigan, and when I got there the program would not open and I've had the aforementioned problems since. I 'm at my wits end. Any clues?
William Holland is offline   Reply With Quote
Old December 1st, 2008, 08:42 PM   #2
tried trashing prefs?
restarting the computer?
Sounds like a data rate issue?
At a loss, but thought I'd suggest the basics.
always learning
www.phillippalacios.com
Phillip Palacios is offline   Reply With Quote
Old December 1st, 2008, 11:41 PM   #3
thanks
i trashed all the prefs, took quicktime back to 7.3, and restarted. I'm upgrading to leopard and going to see how it works out. should have more details tomorrow.
Old December 2nd, 2008, 12:01 PM   #4
reinstall
I reinstalled the os, and everything is working fine. Now, does anyone know how to reinstall quicktime pro? do i have to call apple and harass them to re-authorize my software?
Old December 4th, 2008, 01:06 PM   #5
should be qt pro with fcs... i never "purchased" qt pro, as fcs installs the pro "key" when you install it.
did you re-install fcs as well?
always learning
Old December 5th, 2008, 10:28 AM   #6
hmm...
I talked to my administrator and it turned out he had the key for my computer. Good times. Got it working!
