Sounds like the extension cable is a mono TS cable, not a stereo TRS cable. With a mono cable, only the left channel in the camera will record as that is the signal that is on the T(ip) connector.
The Videomic is a mono mic but its cable ends with a TRS stereo plug with the tip and ring shorted together so the mic signal will go to both the left and right channel in the camera. Using a mono extension cable will put the signal on the left channel only, shorting the right channel to ground at the camera.
"To be or not to be, that is the quizornenplatz" - Monkey #19,483
