F350 timecode burn question at DVinfo.net
Old December 2nd, 2008, 03:42 PM   #1
MPS Digital Studios
Hey everyone,
With the F350, I need to dub some footage to DVD for clients, and I have the camera hooked up to an ioHD via HD SDI, then out from the ioHD into a DVD player. How can I also output the timecode for a timecode burn when outputting via HD SDI? What about composite, component, etc.?
Thanks in advance!
Heath
My Final Cut Pro X blog
Old December 2nd, 2008, 04:57 PM   #2
AS far as I know I can only output burnt in timecode from Composite out on my F350.
That only gives you SD. If you take it in to Avid or FCP you can do it there.
Roddy Jamieson
Roddy Jamieson is offline   Reply With Quote
Old December 2nd, 2008, 09:27 PM   #3
Ditto. You output timecode from the composite output in SD.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply
