Originally Posted by Robert Bec
I am sure you can capture to prorez through the decklink intensity or extreme card. The Aja cards are alot more expensive which card would you recommend
Yes, no doubt you can capture to ProRes via Decklink; I didn't mean to imply you can't. What I mean is that having a card that is hardwired with the ProRes codec gives the AJA an edge if your workflow is centered around the ProRes codec.
I do realise the AJA are a bit more expensive, but it may or may not be worth the extra little investment -- that's for you to decide.
