Originally Posted by Mike Barber
Yes, no doubt you can capture to ProRes via Decklink; I didn't mean to imply you can't. What I mean is that having a card that is hardwired with the ProRes codec gives the AJA an edge if your workflow is centered around the ProRes codec.
I do realise the AJA are a bit more expensive, but it may or may not be worth the extra little investment -- that's for you to decide.
Thanks Mike i will look into the AJA cards
none more question does it matter how many drives i have raided will the drives run faster if i have more drives raided together.
And i think i would like to raid 2 1TB drives just so i dont have to purchase a raid card will this do working in Prorez
Rob
