HF10/HF100 color issue? at DVinfo.net
Old December 4th, 2008, 09:13 PM   #1
I pulling out my hairs, please help me out...
I recently purchased Canon HF10 and were shooting outdoors most of the time. A couple days ago I shot a video indoors and noticed that some colors look a like while being totally different.
I made a couple tests and saw the same. Please see attached the picture of the carseat and my wife's shirt. First picture is a still picture taken by HF10 - note the orange color of the carseat and pink color of my wife's shirt. Next picture is a captured frame from video clip - both colors look almost as red!
---indoors (still from camcorder)---
---indoors (frame capture)---
Second set of pictures were shot outdoors. Better but still far from still picture:
----outdoors (still)----
----outdoors (frame capture)---
I see a lot of people saying on forums how great and bright colors are on HF10/HF100, but what I see is a total mess...
I tried to change White balance, applied custom color settings like color depth - some of them helps a bit, but still pink looks like red and orange like another red :(
I like the colors on still image but I cannot get the same colors shooting video.
Appreciate any comments or help
Boris Key is offline   Reply With Quote
Old December 4th, 2008, 10:05 PM   #2
The still images are coded using a different method than the video images, one being jpeg for stills, the other being AVC/h.264 for video.
Each has its own color palette and different ability to preserve color accurately.
The still camera records a much wider range of color values than the video capture. Even though the same sensor, same lens, and same scene are being used, the still recording has more color detail.
This is the way consumer camcorders are designed.
Larry
Larry Horwitz is offline   Reply With Quote
Old December 4th, 2008, 10:26 PM   #3
Thanks, Larry!
Another my mistake that I was using internal decoder of my favorite player (KMplayer). When I switched to ffdshow it got better. But still not so vivid orange like on the still picture
Old December 4th, 2008, 10:28 PM   #4
Looks to me like you might be using the cine mode, which might have similar effect, did you?
I will try the same tests as well and report back with my findings.
Lost signature, if you find it, please return it to me, thank you.
Mugurel Dragusin is offline   Reply With Quote
Old December 4th, 2008, 10:39 PM   #5
My results, using same custom white balance setting on both.
HF10/HF100 color issue?-still-mode.jpg   HF10/HF100 color issue?-capture-mode.jpg
Old December 4th, 2008, 10:44 PM   #6
wow, looks very close, Mugurel!
can you say what software you used to capture this, rendered and decoder?
I wish I could do this as close as you did!
Old December 4th, 2008, 10:52 PM   #7
For the video part I use VirtualDubMOD and the decoder is CoreAVC (Money well spent). I am on PC here.
Old December 4th, 2008, 11:04 PM   #8
thanks again! it means it is not the camcorder that do the mess but decoder. I am relieved now :)
Old December 5th, 2008, 12:31 PM   #9
there is more details here
http____forum.videohelp.com/topic360522.html?sid=8d9c910bbe54127fbd7723a0a0d21fc5#1914925
