Small companion for my Z1... at DVinfo.net
Old December 8th, 2008, 09:00 AM   #1
I have two Z1's and I'm looking for a 3rd camera... something much smaller that I can use for my Merlin (I'm no Popeye). I'll need something that's close the quality of the Z1's (obviously) and was wondering if anybody had any suggestions.
Wasn't sure if the HVR-A1E would be a good choice or the Canon HV30, which is more than half the price.
Blake Cavett is offline   Reply With Quote
Old December 9th, 2008, 03:02 AM   #2
I would question the A1s low light and the HV30 might be difficult to match with the Z1. How about the Sony SR11/12? We have 3 of them which we use as unmanned cameras with our Z1s.
You'll need to be prepared for the AVCHD files though..
www.springproductions.co.uk
Tony Spring is offline   Reply With Quote
Old December 9th, 2008, 03:31 AM   #3
Hi Blake,
I regularly use a Sony HC9 on my merlin and mix it with Z1 footage. If you avoid high contrast extremes (eg. white shirts against dark backgrounds), the footage is almost indistinguishable, easily matched up in post. With a wide-angle lens and large battery it's relatively easy to use on the Merlin and I can just leave it on there, frequently switching from handheld and tripod-mounted Z1's to the HC9 on Steadicam.
I initially bought the HC9 as a capture device, but after trying it out on jobs I now use it all the time.
Oh yeah, it's also HDV so the workflow remains the same.
Tom Vandas is offline   Reply With Quote
Old December 9th, 2008, 08:06 AM   #4
Images: 10
I know it's not what you asked, but expecting an exact colour match, even between the same model of camera isn't realistic.
I personally use an HV20 as a companion to my Z1, it a great picture when used under good lighting conditions.
Old December 9th, 2008, 03:04 PM   #5
Thanks for the responses! I'll be checking these cameras out!
Old December 11th, 2008, 07:15 AM   #6
Keep in mind "exact color match" is iffy even between two identical cameras sometimes...
BUT, I'd say that Sony cameras will more likely be closer to the "Sony look" for want of a better term... Canon has a different "look" from what I experienced, not necessarily better or worse, just "different".
SO for the Z1, check out a used HC7, the newer HC9 (pretty much the same as the HC7, in black, just a few minor differences) - that's if you go with tape. If you open up the AVCHD option, SR11/12 or the CX12 are options.
A wild card - in the "small camera" section of DVi there are some good reports on the HG21 from Canon...
Old December 11th, 2008, 07:31 AM   #7
i have an HC1 i will sell you for dirt cheap. i use it as cutaway with my sons all the time.
Scott Hayes is offline   Reply With Quote
Old December 16th, 2008, 02:27 AM   #8
I have a Z1 and use a HC9 as second camera. In normal light condition you can't see the difference. In low light situations there is difference... the Z1 is the winner.
I use the HC9 also mainly as capture deck..
Pol Van der Plaetsen is offline   Reply With Quote
Old December 18th, 2008, 11:27 PM   #9
i use the HC1. It was a great companion to my FX1 but not so to the EX1!
Old December 27th, 2008, 07:13 AM   #10
Do the hc series have the chance to split between Pal NTSC mode?
What's the price range of this small hdvcameras?
thx
Marcus Martell is offline   Reply
