DVD Studio 4 help at DVinfo.net
Final Cut Suite
Old December 16th, 2008, 10:57 AM   #1
DVD Studio 4 help
I know the answer to this is probably Really simple but I need help. I'm using DVD Studio Pro 4 to make a DVD. I have a a video track as the first play option and I don't want anyone to be able to skip past it. How do I prevent this?
Shaun Conner is offline   Reply With Quote
Old December 16th, 2008, 11:36 AM   #2
For the track you want them to not be able to skip, go to the User Operations tab and disable the controls.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old December 16th, 2008, 03:40 PM   #3
I did. I disabled all user options but it still allows you to skip the track and go to the menu.
Old December 16th, 2008, 03:42 PM   #4
Are you testing this in a DVD player or the DVDSP simulator? You should be testing it in an actual DVD player.
Mike Barber
Old December 16th, 2008, 07:25 PM   #5
Oh ok. I tried it in the simulator. I'll burn it and then try it. Thanks for your help.
Old December 17th, 2008, 12:21 AM   #6
Disable skip
Shaun,
Make sure you are in the advanced settings tab.
Click on your track.
Click on the connections tab.
Make sure that "next" is blank and set the "end" field to what you want to play after your track.
Hope this helps.
Jonathan Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply
