How to Convert EX-1 to SD for DVD ????? - Page 4 at DVinfo.net
Old January 3rd, 2009, 08:00 AM   #46
Having spent many hours experimenting the best results I have achieved so far are by shooting in SP 1440 x 1080 60i (my project will be in NTSC). Dropping the footage straight into the Premiere timeline and then using Adobe Media Encoder output to MPEG2-DVD using NTSC Progressive Widescreen, Field order is set to None (Progressive).
The quality of output is outstanding. I shot the same sequence on my Canon XH A1 in SD mode and created a DVD, then compared the two and the Sony EX3 was far superior. I also tried setting the Field order to Lower and had problems with Moire patterns on blinds in the window, fence etc. I also ran the same footage through VirtualDub, and although a still capture showed the VirtualDub image to be better, it didn't show a marked difference on the actual footage. I can see why some people have recommended this, but for me it is just another process that gets in the way of my project.
I also spoke with Sony UK yesterday and asked them what was the best method for converting to SD. They recommended shooting everything in HD (1920x1080) and use ClipBrowser to Export as an AVI file. Then dropping the AVI into your timeline. THis produced a horrid result, certainly not doing any justice to the EX3/EX1 camera.
For the time being dropping MPEG footage straight into the timeline as described above will produce a great looking movie. I will try some other techniques later on, but for now I will shoot my next DVD using this technique.
Thanks for all the help and advice.
Vincent Oliver is offline   Reply
