Jerky Pans - Premiere CS2
I've been a CS2 user pretty much since it came out and never had this issue before -
I have several short clips in a sequence with pans (not an effect, straight video). I started noticing that the preview display of those clips was jerky (like a sticky tripod head might cause). The original video is totally smooth. I blew it off thinking it would render fine. Wrong. Export to DVD or export to an AVI file retains the horrible movement. After much investigation (and some luck) I determined that if I render right after a re-boot everything is fine. Other system behavior that may or may not have anything to do with this are: 1) When I play a DV-AVI file with Windows Media Player I have to click in the play area to get the video to appear (the audio starts right away). 2) When I play an un-compressed AVI file with Windows Media Player I get a codec error and only the audio will play. Thoughts? |
Larry,
Maybe your PC has been bogged down and you are lagging? |
