Making Magic Bullet Looks work in CS3 - Please Help!!!
1 Attachment(s)
Hello,
I just purchased Magic Bullet Looks and was excited as heck to get to test it. I downloaded a trial of Premiere CS3 and installed it and then installed Magic Bullet Looks. CS3 sees the effects but when I apply the "Looks" effect to a clip and then click "Edit" it opens the "Looks" standalone interface but it does not show a preview of my clip - just a grey screen. I've attached a screenshot below. What is the cause of this and does anyone know how to fix it? Is it possible that it's because I'm using a trial version of CS3? |
Im running Premiere CS3 with Magic Bullet for Editors installed. I didnt know if it would work as it was made for prem 2.0. While im still testing it, so far its worked. I did have a crash on a rather large project, but im not sure if it has anything to do with magic bullet. It could be that you have the trial version.
Anyone know a solution? |
It may be a video overlay problem....
what video card are you using... |
1 Attachment(s)
I'd suggest you could be right given the 8 series has full screen video overlay disabled (which I wasn't using anyway), but Red Giant's Magic Bullet Looks FAQ page lists the 8800 as a recommended card for Looks, so I'm confused. EDIT: Just disabled the 8600 and tried it with a single monitor out of the 7800 and it still failed. Just a grey screen. Everything else about it seems to be working fine though. This is annoying. EDIT: I have a feeling that it is just opening the standalone interface without linking it to CS3. The screenshot attached shows that down the bottom right there is no "OK" button to return the look to any host application. It should definitely be there!! |
You say you had Magic Bullet Editors working with Premiere CS3? I recently tried installing it with CS3 and the effects don't seem to show up in the effects palette.
Looks is the updated version I believe. |
1 Attachment(s)
When I click on "Video Effect" the attached screenshot is what I get.
Interestingly, all of the presets for "Misfire" are listed under Misfire but none of the presets for "Looks" are listed - but I don't know if they're supposed to be. I don't think they are, because I got this running on my sister's laptop with exactly the same software - trial of CS3, trial of Prospect HD & purchased Magic Bullet Looks and it worked like a charm. On my PC though... still no good... |
Look for the MB Looks in a different folder under effects, they are Presets not Filters.
The Magic Bullet Looks filter that is in there with the Misfire stuffs is all that controls the whole gizmo! The rest are presaved custom presets that are in a folder in effects somewheres :) Carl |
I just looked through every folder and found nothing. I'm not sure if you're supposed to be able to access the presets from the CS3 effects panel though, rather you simply apply the "Looks" effect and then click "Edit" and then manipulate it in the standalone interface and select your preset in there... I think... |
I've only used it with PPro2.0 so I cannot really say as far as CS3; but the way it works with 2.0 is there are a bunch of presets for the looks effect (if that is what you are looking for) as a separate folder under effects. Has the same icon as your Presets folder above it.
It's a top level folder, such as Presets, Looks Presets, Video Effects, Video Transitions, etc. I wish I could help further, but I haven't used CS3 + MBL. Sorry! C |
I'm very frustrated. I have contacted Reg Giant support but have heard nothing for almost a week. |
Indeed. Now I'm a little leary of purchasing Looks for CS3. I'd download and test the trial version to compare notes but, as you've already said, THAT worked. I'd stay on Red Giant though. If I do decide to purchase Looks I'll check back with this thread ASAP and let you know if it does the same for me.
