Premiere to Encore CS3 out of sync audio?
Editng HDV in 23.976fps in premiere - then export to encore - Everything plays on the computer timelines in Sync but the final dvd playback on a dvd player is out of sync by about a frame or 2?
Why is this happening? What can i do? |
No, I was wrong, its actually out of sync by 7 frames.
I know this b/c i have to push the audio over 7 frames to get it sort of in snyc for when the DVD is burned. Plays out of sync on multiple DVD players tested. Like i said, everything is in sync in the computer playback, until i get a disk burned.... Encoding done with Premiere. |
Tyson, it seems CS3 has a well documented audio sync problem with HDV. If you do a search on these boards you will learn more. I am not sure if I've actually heard of a definative solution though.
Ive searched a lot. Found some forum on Adobe site where they were having same problem but no solution. Guess i need another DVD burning program.
Has anyone found a solution for this yet? I'm really frustrated by this. I can't export to quicktime with out having completely out of sync audio.
Open your video clips in Audition or Soundbooth and then export audio as 48,000 Hz/16bit and use those audio files to replace the ones in Premiere.
Sounds interesting....but how do you get them out of Audition or Soundbooth so I can export them to a format so QT can convert to h.264?
