How do I render an HDV file back to HDV codec??
I have captured footage in HDV from Canon XHA1.
Now how do i render my final project back to an HDV file for delivery to a client who wants it as the originating format? |
Thanks but..
thanks but not very satisfying answer.
Why wont premiere just let me render back to an HDV format .m2t file from export movie window instead of having to do a trck. What format do "THEY'' want us to be using as a finishing format for delivery to someone else? |
It's not what "THEY" want. It's what YOU want to delivery your video to what target audience. There're all sort of final delivery format under Adobe Media Encoder.
You can export back to MPEG-2 format using Adobe Media Encoder using 25mbps bit rate and 384k MPEG audio. That's close to HDV format. |
Im just asking;
What is the "industry standard" Finishing format for video originating on HDV?
IF there is one... With DV it was easy. Start on DV, Finish back to DV. |
If you have the cineform codec installed, you should be able to go File > Export > Movie > properties > and then choose the cineform codec.
Cineform HD
I don't have Cineform HD.
Is that the official answer. Buy Cineform HD? If i did it would be easy. Let me explain the problem were having. This file has to be rendered and sent to another facility that does not have cineform HD on there machines. The person with the original footage is the shooter who captures the shots, and wants to render the good takes as a single HDV file and then send over FTP to the other editor/compositor a single .M2T file. The problem is rendering an HDV single .M2T file. Now i realize that HDV is not the best format for this process, but thats what the compositor wants. As far as i can tell you cant render back to HDV easily. Perhaps they dont want you to do this. |
I think this is the reason why it's not supported, nobody would generally like to use that as a delivery format. What I suspect the shooter wants to do is to capture the raw data from the camera. Probably he/she thinks that this approach would work to get "untouched" footage from the camera. This would work is you make a single file out of each tape. If this is not the case then it's the best to convert it to any of the many codecs supported by QuickTime, one that is lossless, like Uncompressed, burn it to a DVD and Fedex the disc. Transferring HDV file via Internet takes too long. Quote:
Hope this helps. |
Good answer
Thanks Paolo,
That was what i was wanting to hear. Still the problem with doing quicktime Uncompressed is its enormous file size. Certainly there is a compressed format that I could be using that is avalible in premiere that is near visually lossless. |
