Slowdown using key frames...Suggestions?
I've been using Premiere 3.0.2 for about 6 months now. I did search the forum for this issue, but came up empty handed.
No problems at all with capturing from two cameras and digital audio source(s). All other edit processes work great. However, I've noticed lately that there is a slowdown in response time when I change a keyframe marker on my timeline. It takes about 15 seconds from the time I move a keyframe marker untill the program lets me move on and do another edit. I have done many suggested things, defrag, virus scan etc., etc. I'm using a duo core processor with XP and two gig of ram. Any ideas and/ or suggestions? |
Adobe has released several updates since 3.0.2. They're now up to 3.1.1. or 3.1.2. Don't know if the updates would fix your issue but worth a try.
Is the behaviour specific to this project or does it occur in every project? Maybe your project is corrupt. Happened to me more than once...
Thanks Bart. Yes, every project on my computer and my wife's computer too. |
I have CS3 set to search for updates weekly, but you could just use the Update feature on the Help or Window menu (forget which, and capturing a long tape now so can't check)....
Thanks....Bart, you might be correct.
Adam,
Thanks for the tip. I went to the update heading in the HELP section. All it updated was Adobe Reader. No mention there of anything else. I'm still looking....... I did "restore" my computer in hopes of getting rid of what ever is slowing down the process. Of course I had to reinstall Premiere, but the problem still exists. At least with that project. I can't figure out why there is no problem until I render the partially edited project and then things slow down... |
