Brightness & Quality of Firewire & exporting
Hi
I use cs2 I had a video which was pretty low light. As soon as I added a video effect to lighten it up the quality deteriorates. Is there a better plugin although when I seem to change any variables the quality goes. I use an xh a1 and capture via firewire. Is there better ways to capture and if so why? I export in Microsoft DV AVI. Should I be using a better filetype/codec. Many thanks in advance |
Care to explain, no, no.
It becomes alot more pixelated.
What video effect did you use?
The best solution would be to re-shoot, the second best may be levels. |
