Using trademark symbols in premiere
Hey- does anyone know an easy way to insert trademark/ registered/ copywright symbols into titles in premiere? Is there a keyboard shortcut or symbols library I don't know about?
The easiest way for that, due to the limitations of Titler, is to make a separate TXT file that contains all these symbols and use copy/paste.
yep - you need to hold down alt, and while holding it, enter 184 (but quickly). All the ascii codes can be entered this way - there are all sorts of weird symbols available.
You can go to "character map" copy then paste to get the © and ® symbols
Thanks for the help!
