60i in a 24p timeline
Hi all, I need to make a 24p timeline that will have quite a bit of 60i in it. What is the best way to make the 60i play normally or like the 24p at regular speed? Thanks TAG
1 Attachment(s)
Use the interpret footage feature ...right click on the clip in the browser, select interpret footage, change as needed: Adobe Premiere Pro CS4 * Modifying clip properties with Interpret Footage The jpeg shows what the screen looks like, with a 1080 60i original conformed...you may or may not want to change the aspect ratio, field order, etc, but this is where you can do it...hth/ Battle Vaughan
Thank you Mr. Vaughan, Does it do that in CS3 also?
