Premiere pro CS4 will not export audio.
I am unable to get any audio out of Premiere Pro CS4. I've tried all different codecs but it still doesn't work.
I was able to export audio before just fine. The audio works just fine inside Pr and the video exports fine. Could it be the Pr Pro CS5 trial causing this. Help would be much appreciated. EDIT: Problem solved! I did some messing around and found out that I can export audio only if the "speed/duration" is set to 1000% or lower. So to get a speed over 1000%, I just save/render my audio out at 1000% speed and then bring the new audio file into Pr, then give it a speed of say 500% to get a total speed of 1500%. |
