Sorenson Squeeze Framerate problem
Hellow Everyone...
Here I am again for a problem I have with my Sorenson Squeeze... When I render the movie in adobe I use 25fps, so the mpg movie (source file) is 25fps for sure. The movie plays very smoothly when I check this. Then when I upload the sourcefile into Sorenson Squeeze and I want to set the framerate to 25fps or 1:1, Sorenson automatically changes it (when I reopen the settings-window) in 19,893 fps. I searched but I found nothing. Off course when I render it, it is not smoothly at all, because off the frame rate that is to small.. Can someone help me please? Thanks a lot G |
Not sure why you get that problem with Squeeze. Which version of Squeeze do you use?
I'm using v5 and have never encountered such problems. But why do you first encode to mpg in Premiere, and then import the encoded mpg file into Squeeze? This doesn't make any sense, as you will then do a 2nd encoding and probably lose quality. Why not export as .avi from Premiere, and let Squeeze do the encoding of this file into whichever format you choose? Try this, and see if it makes any difference? |
Ok Trond, thank you very much for your help. I shall see what result it gives...
