Time Ramping Speed Faster Than 1000% in Premiere CS5?
Anyone know a way to speed up time ramping greater than 1000%?
For now I'm putting my clip into nested sequences and ramping each up to 1000%. I need to be at around 3500%. Surely there's a better way with more control than nested sequences? |
No one? I'd like to do all this in Premiere, but do you know of a way to do this in AE if there's no way to do it in Premiere?
Hi Lloyd,
I am not sure if there is a direct way, but one thing I have done is to ramp it up 1000% then encode the clip to your final format (such as mpeg-2) and then bring it back into PPro and ramp it up a second time to reach the speed you want. Unless this is going to a high-end final product, the result should not lose much quality. Alan |
the ramping goes up to 1000% when you use time remapping on the timeline. But IIRC if you change the speed via right click menu it goes higher than 1000%.
Hi Zoran,
Many thanks, that is certainly the best way to do it -- I wish I had noticed that earlier! Alan |
try this, ramp in and out up to 1000%, and then cut in between and adjust the speed as needed. Use a short cross dissolve between the cuts.
Re: Time Ramping Speed Faster Than 1000% in Premiere CS5?
Thank you so much for this! |
