Trying to combine Audio Channels
Hello Fellas,
I have been trying to figure, probably the simplest thing on PPro. I have a Video/Audio track that was recording in Stereo but with only 1 channel. Is there an easy way in PPro to combine both channels and have have both L and R played specific audio? Am I missing something on the Effect tab for Audio? Thanks again you guys and advise right now would be AWESOME!!! |
Select audio "fill left" or "fill right" if you want to fill the left channel or the right channel....
really?!?! that easy... ok, time to jump off my roof...... unto a trampoline :-)
THANK YOU!!!!! |
I'm rereading your op....if you recorded one channel, what you will get with the fill is, of course, a duplicate of the channel you're copying. It will not make stereo separation out of the one channel, if that was what you wanted. But it will give you sound from both channels instead of just one, which is a good thing...PS, "fill Left" means take the left channel and copy it to the right channel, which seems just backward to it's description, it's an Adope thang......
Guys here's some other options .. pan that one good channel to the centre or How to Use Mono Audio Clips in Adobe Premiere Pro | eHow.com
Cheers. |
change your default channel mapping from stereo to mono. then when you edit to the TL, just have the correct track enabled to insert only the good audio channel.
More Info on Combining Audio Channels
Hi Guys,
It's Kevin from Adobe Learning Resources (we take care of Premiere Pro Help). Great discussion! Want to find out more about how to combine audio channels? I've got related topics for you culled from Adobe Premiere Pro CS5 help. I hope this clears up any questions you may have. Adobe Premiere Pro CS5 * Fill Left effect, Fill Right effect Adobe Premiere Pro CS5 * Preferences Adobe Premiere Pro CS5 * Targeting tracks |
