-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   options in order to use a Reference Monitor? (https://www.dvinfo.net/forum/adobe-creative-suite/492500-options-order-use-reference-monitor.html)
Dave Morgan March 1st, 2011 11:30 PM
I use premiere pro cs5 and am looking for a way to view HD on a reference monitor/hdtv I have a video card that has HDMI out but i don't believe that would work the way a reference monitor should work correct?
so what are the options for $300 or less. thanks
Robert Young March 2nd, 2011 12:23 AM
Re: options in order to use a Reference Monitor?
I'm not sure precisely what you mean by "reference monitor", but the HDMI out from the graphics card will certainly work well with an HDTV.
If you hook it all up & turn it on, set the video card for "dual screen" output, then go to the Playback Settings in PPro and set the external monitor settings appropriately, you will get full screen playback on the monitor from the timeline, source and program monitor play, and clip preview playback in the Project Panel.
A true reference monitor will work the same if it accepts HDMI.
If it only accepts Display Port connection you may need to obtain an HDMI/DP cable/adapter.
Kelly Langerak June 29th, 2011 01:35 PM
I'm looking into these two monitors to do color correction on when using FCP 7. I mainly do wedding videos that go to Blu-ray and DVD.
I have a recent Mac Pro Quad Core / ATI Radeon HD 5770.
Right now I'm using 2 consumer monitors but want to replace my LG with one of the two options below..
Will these do the job. I don't want to have to upgrade till the monitor is dead or obsolete.
1. http://www.bhphotovideo.com/c/product/676418-REG/NEC_PA241W_BK_MultiSync_PA241W_BK_24_Widescreen.html
2. http://www.bhphotovideo.com/c/product/706684-REG/Eizo_S2433WH_BK_FlexScan_S2433WH_BK_24_1_LCD.html
Do I need a video card and do I get "10-bit" playback on the calibrated monitor?
Please add any additional info that I may want to know.
