Looking for some to write custom Premiere plug-in
Hello
I am looking to find a programmer with a working knowledge of writing plug-ins for Premiere to write a custom plug-in for Premiere CS5. The plug-in is extremely simple. It will be a Video Effect that can be applied to a clip on the timeline. It has one control that slides the top half of the clip to the left and the bottom half of the clip to the right; by a user defined number of pixels. However the plug-in then needs some kind of global control that allows the user to change the functionality of ALL instances of the effect in the current sequence - so at a command they slide the ENTIRE image left or right, and not just the top/bottom half. This could even be implemented by writing 3 plug-ins and shutting down Premiere, substituting the plug-in file on disk and re-starting it. The reason we want this is that it will enable us to handle changing the depth of stereoscopic 3D clips in a Cineform workflow. This is a paying job and anyone interested should email me at ben@redstar3D.com I can supply more detailed information about the functionality if needed. /ben |
Re: Looking for some to write custom Premiere plug-in
Hello
Is there someone out there that replied to this thread in August of last year and wrote us a plug-in called RedStar3D which we use to change the convergence of a stereoscopic clip in over-under mode?! If so please email ben@redstar3D.com thanks! /ben |
