Effect not working - PP5.5
I can not figure out how I can apply a fade out (opacity) in the end of a clip I slowed down (slow motion). The effect do not work, despite I can see the keyframes (opacity) in the timeline. Premiere Pro 5.5
Thanks |
Re: Effect not working - PP5.5
You can use cross-fade transition to the same effect, maybe this one will work.
Premiere applies the time stretch last, so the opacity change is not where you think it is. The easy solution is to right-click on the clip, then choose to nest it. Then apply the opacity changes to the nested clip.
Thank you both
In fact I decreased the speed to 1% - freeze frame. Bill, your sugestion worked. Appreciated. |
