Is Cineform worth the money
OK so I'm quite happy with my HDV footage at the moment (don't get me started on the audio synch issues though!!!) but having read about Cineform thought I'd give it a try. I've read good things about it's quality as a capture/editing codec
BTW I'm currently shooting and editing 1080i PAL So I downloaded Cineform Neoscene trail and captured some footage - imported into CS5.5 and ..... well I can't really tell much difference - so what's the deal and why does it get good write-ups? Am I missing something? Pete |
Re: Is Cineform worth the money
First try the free HDVSplit capture utility. Great for capturing, no audio sync issues and no conversion, so you can continue editing native.
If you have footage that needs heavy post processing, I suggest you use TIFF image sequences instead. If it's a 'straight' edit, then edit native HDV. |
Hey Peter....
Cineform was, and still is a great codec. It came out at a time when hardware was expensive, computers were slower, and HDV was slow to cut...3rd party codecs were a great option for those of us on a budget. Unless you're doing 2K or better, cineform's engine isn't the direction you need to go. Especially now that you're working with CS5.5, and using a decent computer, you should be able to cut through HDV, and still have no problems with color correction. |
For a HDV-only workflow, you don't need Cineform and probably won't see any benefits at all, unless you are doing really heavy grading. I always edited HDV natively when I shot with Sony HDV cameras, and never struggled too much with it at all.
However once I made the jump to AVCHD and Canon DSLR's, Cineform became invaluable to me. It speeds up my editing, and gives my footage uniformity (at the moment I deal with AVCHD from Panasonic and Sony, Canon MXF files, DSLR footage from Canon and Nikon, and GoPro footage as well. Cineform lets me transcode everything so it is all the same, and will mix effortlessly on the Premiere timeline. I will be upgrading from CS3 to CS5.5 this month (and CS6 soon afterwards, thanks to the free upgrade!) but I think I will still keep my Cineform workflow. Sure, it takes a little time to transcode the footage but the files cut like butter and give me a much more enjoyable editing experience. |
What about Canon DSLR CS5.5 without mercury card. Is it better to convert or not?
I love Cineform. Don't use it much these days for HDV but will use it for the GoPro.
There is now a free app to convert GoPro to CF.avi (Cineform Studio) Also use it as an intermediaire codec from AE to Pro when rendering with DL is going to be a pain. |
I agree with Ann and Peter, Cineform codec is terrific and still useful.
In the early days of HDV it was Cineform that allowed me to even get the job done at all. Now, with AVCHD, CS5.5, and fast, powerful hardware, I usually edit in native formats for short programs. However, I just finished a 60 min doc that had more than 2,500 clips logged in, extensive color correction, motion stabilization, etc.- done with CF. Maybe I could have edited it in native AVCHD, but I knew from experience that a big project like this would be problem free using Cineform DI. Additionally, when completed I can render out a 12 bit, 4:2:2, 1920x1080 master CF.avi movie that will be the basis for high quality transcodes to any delivery format needed for now or in the future. |
We only use Cineform for exporting our masters, but we're seriously considering switching to Avid DNxHD in this regard. Export out of After Effects is usually uncompressed or animation codec.
As others said, there used to be time when Cineform was very valuable, but nowadays we found it using less and less. It's a pity it did not catch as a recording codec like ProRes or DNxHD. |
I find the Blackmagic mjpeg avi codec to work great and it is free. It is not the best quality but the files are a manageable size that they do perform much faster in Vegas 11 compared to AVCHD. The render speed is also much faster then the painfully slow DNXHD quicktime codec.
We use Blackmagic cards during live corporate events and sometimes we have to do quick trims in Vegas in the field for playback for another portion of the event. We use the mjpeg codec and Vegas slices through the files like butter and renders super fast with the "no render needed" direct frame copy. I trust playing out with that format back through the Blackmagic cards then any other native format. |
I am also preparing for a CS3 to CS5.5 (+6.0) upgrade. Thanks |
Matthew, for HDV only projects I used to edit natively. If I am mixing footage (say, a wedding shot with a combination of DSLR & XHA1) then I will transcode everything to Cineform so it all matches on the timeline.
Other than that I don't have any particular workflow for going to DVD - just render a mpeg2 straight out of CS3's Media Encoder. I also turn deinterlacing on when going to SD, as it eliminates any discrepencies that might have existed when mixing different footage types, and because the resolution hit doesn't matter too much for SD delivery. With the DVD presets in Adobe Media Encoder CS3 make sure you bump up the default settings for bitrate, as they are a bit low to start with. If you're putting just over 2 hours onto a dual layer disk, then you're then you're got plenty of room to move with bitrates so you can push the target and minimum bitrates up to almost match the maximum bitrate. |
