Premiere Export - need a certain format
Hi Guys
Hope you can help! I'm running CS5.5 on Windows and I need to export to the following spec: Wrapper Format: Quicktime mov Compression Format: Apple DV PAL I had originally exported using Quicktime > PAL DV Widescreen - but I've been told that this is DVCPRO and does not fit in with the above spec. I can't seem to figure out in the format or codec list, how to achieve this spec. If anyone has any idea, I would be extremely grateful. Daniel |
Re: Premiere Export - need a certain format
Hi, i am on a mac and my camera guy use to send me windows files out of CS5, I had to open them in MPEG Streamclip, and re convert them, may you could export the video, and then try to convert them. May help.
| All times are GMT -6. The time now is 11:50 PM. |
