External Hard Drive Recommendations
Hi all - I want to buy a couple of 2TB drives to use with my laptop which has firewire and USB 3.0 - I will be wanting to edit the footage on the drives - they won't be just for storage - any recommendations?
Re: External Hard Drive Recommendations
1 Attachment(s)
Well I use the WD My Books. I have two 1Tb drives and two 2Tb drives, all USB3 and surprisingly fast. I have actually lost one of them, in all fairness, but they are very effective, and usable in most workflows.
You may want to consider something like this: Plugable| Plugable USB3-SATA-U3 USB 3.0/2.0 SATA Hard Drive Docking Station (ASMedia 1051E Chipset)
The increase in versatility one of these provides is quite astounding. Basically, you have just one (or in your case, two) docks but as many "bare bones" hard drives as you need, if you check the "gigabyte per pound" figure in the UK you can save a bundle by just buying the drives that give the most bang for your buck. Something like this should be in the running I reckon: Seagate ST1000DM003 Barracuda | Seagate In case this option hasn't passed you way before, the drive simply plugs into the top of the "toaster", just like a slice of bread, you hit the power switch and hey, presto, a new drive on the system. Finished with the drive? Simply hit the "Detach connected hardware" icon bottom right of your screen, wait till it gives you the ok, then power the dock down and remove the "toast" from the "toaster". Slot in another drive for a second/ third or fourth application and off you go again. Should be pretty quick on a USB 3 connect. They're magic for doing rolling backups, which is what I use mine for. Think of it as 1 TB floppy discs, but ONE HECK of a lot faster! CS |
Chris I've never seen these before - I'll see If I can find a UK supplier - I was looking at Seagate Expansion 2TB drives but cannot determine the RPM - even Seagate don't know - here is there response to my question
"we cannot determine the speed of a hard drive inside and external enclosure. when it comes to external hard drives, the internal speed "5400-7200" does not matter, since they are designed to operate at USB2.0 or USB 3.0 speed." |
To quote a well known phrase or saying: What utter cobblers!
Every drive is quite clearly marked with its rotational speed, the one I pointed you to yesterday is most definitely 7200 rpm. The speed of an external drive is no less relevant than the speed of an internal drive, especially as USB 3 is pretty well the same interface speed as Sata 3. I am not, however, suprised at what you reported them saying, it is not the first time Seagate have opened their mouths and instantly stuck both feet straight in. Just to expand on my comments on docking stations, a trawl of the net will quickly throw up that they can be had with (just) about any interface known to man, a Thunderbolt is on the way as I type. Some only have one, some two, some 4 (though I'm struggling to remember what the 4th is). As I said yesterday, do investigate the cost per gigabyte of the available drives on the market, here 1 TB is by far the best bang per buck, so, in effect, you can buy 3 X 1 TB drives for the same price as 1 X 2TB drive, or pretty close. Do make note that although most** of the docking stations will take up to a 4 TB drive, Windows XP limits any hard drive partition to 2 TB, so you're on a bit of a hiding to nothing buying larger than 2 TB if running that OS. ** = Some will only take a max 2 TB drive. Check. Oh, and all the docking stations I have investigated will take both 2 1/2" and 3 1/2" drives. CS |
based on my experience, i do NOT recommend WD MyBooks; neither will play nicely on my USB 3.0 slots (Rampage III Gene; everything else works fine) and they BOTH have a habit of dropping out and i have to power cycle them.
However, if one were to buy them and gut the hard drives, i can say the bare drives themselves are perfectly reliable. sadly the external USB 3.0 ones i purchased were cheaper than internal 3TB drives. |
Every failed external drive I have ever purchased was a WD MyBook... so I stopped. LaCie exclusively in my edit bay right now. I've had 2 power supplies fail but no drives.
Your mileage may vary. |
Seems it does Shaun and not because we're over 14000 miles away :)
All our drives are WD 7200rpm, never had a real problem. Basically I don't think the WD external drives have enough internal cooling. Probably a size, noise and cost thing and over long sessions the internal heat does build up. Even though the post studio has good aircon, we run additional fans. Cheers. |
Allan that's an interesting point about the WD externals and heat. I've mentioned losing one of my four WD USB3 externals, and they are all lined up cheek to cheek in a row, and do get a bit warm sometimes.
Good gracious. I just peeped behind the big monitor that hides those drives, and there was a box sat right across the top of them, completely blocking the vents! They are not at all warm at the moment, but they would obviously warm up when used. |
Trevor, good catch :) Leave as much space as you can, minimum 5-6cms between each drive.
And if anyone else uses the room, check everything before powering up. A poorly designed enclosure can drive the heat up. Despite the cooling arrangements and testing it by placing your hand on it, that won't tell you how hot it is inside the drive. The first clue some get is a faint burning smell, even before the drive malfunctions. And Murphys law says it'll drop dead the day after the warranty runs out. Cheers. |
i've had a Lacie Big Disk Extreme 1T (replaced power- still doesn't work...) and a Lacie Rugged 500gb fail. That's close to $1000 for two bricks. And a Keiser 500gb failed. and another 250gb that i forget the brand.
Pretty frustrating and some data trapped or lost. Unfortunately i have 4 other Lacie Ruggeds full of data that i no longer trust. I am now trying out a Glyph portagig which 'seems' solid and has a fan. I also have two iomega 500gb that have outlasted the Lacie 'professional' drives. that said, i am finding it harder to trust any drive... would love to know what the rate of failure is for hard drives and if there is an 'expiry date'??? |
I have never had a WD drive fail on me, nor a Sandisk drive. For moving around, I highly recommend Sandisk shockproof drives, I even like the finish. |
I bought an SATA to ESATA bracket for about $3. This allows the internal SATA ports in the computer to be used with external enclosures that have ESATA connectors. It works great for video. |
