Proxy Video Editing (Bait-n-Switch) Method with Adobe Premiere
I revised a blog I wrote back in 2007 about Proxy Editing. Hope it's helpful.
Proxy Editing is a great way to edit video in draft cuts even with a low power processor laptop/ultrabook. With today's high compression complex codecs like AVCHD or MPEG4 H.264, editing with NLE would be challenging on a lower power laptop CPU. The complex encoding scheme makes scrubbing on timeline less responsive. With Proxy files, editing could be done on low power laptops. It also makes possible with DSLR .MOV files doing Same Day Edit at weddings/events with a regular laptop too. To have proxy editing, all source files are needed to be transcoded to a faster codec. These are my choices AVI - Microsoft Video 1 MOV - Sorenson 3.0 or Photo JPEG codec. A tool allowing batch transcoding is needed. Grass Valley Procoder, or Adobe Media Encoder (AME) both allows Watch Folder setup. It's a quick way for automatic batch conversion. With AME, first we need to create an Export profile. For example, a Quicktime MOV preset can be set as follow Video Codec : Photo - JPEG Quality : between 50 to 100. Higher quality takes longer time to transcode. Width and Height : 640x360 or 320x180. Higher resolution takes longer time to transcode. It could be as low as 256x144 for quicker conversion. Frame Rate : 29.97 or 15 for 30p. 23.976 or 12 for 24p. It could be as low as 10fps for even faster conversion. Aspect : Square pixel. For audio codec, it should match the source clip format to avoid any re-conforming of audio in Premiere Pro. For most DSLR .MOV, it will be 48khz, stereo, 16bit. http://lacolorpros.com/blog/images/proxy-edit/ame1.png Once done, save the preset to be used with the Watch Folder setup at Adobe Media Encoder later. In AME CS5.5, you can create watch folder setup at File, Create Watch Folder. Then specify the Format as QuickTime, and Preset with the one created above. You might also check the option on top for "Auto-Encode Watch Folders". This option allows any files being copied to the watch folder to kick off the transcoding process automatically. It is great for working on Same Day Edit when content from memory cards are being copied to computer. http://lacolorpros.com/blog/images/proxy-edit/ame2.png Once the low res MOV files are transcoded, they can be imported to Premiere for editing. The resolution together with frame rate could be low. But it is only temporary and good enough for a quick rough cut. When done, before rendering a full quality version of the project (on the same laptop or at desktop computer), close the Premiere project. Then rename or move away those LQ MOV files. Next time when re-opening the Premiere project, Premiere will prompt the user to locate where are the missing .MOV files. At this time, point back to the original full resolution .MOV files. This "bait-n-switch" fools Premiere to export a high quality full resolution output. I have been using Grass Valley Procoder's watch folder feature to transcode .mov files. The low res files are small and very portable. It makes editing with rough cuts a lot faster and more scrubbing responsive even with a low power laptop. My original blog link : Proxy Video Editing (Bait-n-Switch) Method with Adobe Premiere | L.A. Color Pros Blog |
Re: Proxy Video Editing (Bait-n-Switch) Method with Adobe Premiere
Thanks for sharing the link. The process described in that page is the same concept, creating a low res version for faster editing. However, the offline editing mode in premiere seems more cumbersome at the very end when bring the footage back online. Its in the last step, says,
"Repeat the previous two steps for each low-resolution clip used in the project." The way in my method will not require specifying the hi res clip location one by one. |
