Duplication/replication from Encore
Hi All
I need 150 copies of a 1 hour long event video on DVD. I am trying to organise to send this to a company to do but am not sure what is the difference between duplication and replication? Also, if I export my project from Encore as a master will most places be able to burn directly from that? I have a chapters and menu screen so really don't want it to lose anything in the burning process.. Thanks in advance!!! Kind Regards Diana |
Re: Duplication/replication from Encore
replication and duplication are terms used to differentiate a copy over a DVD-R (chemical process) ou DVD (physical process).
for small batch (under 250) DVD-R is cheaper because you do not need the master disc. If you make a project with Encore and you check it is readable on a stand alone dvd player, there are good chances it will be accepted by replicators. |
Duplication of DVD is simply involves burning copies of the DVD just as you would on your computer.
This results in a DVD-R which technically should not be labeled with the "DVD Video" icon. This is usually cost effective for the quantities you mentioned. Replication involves making a glass master DVD stamp, which is used to stamp out large quantities of DVD quickly and accurately. This produces a DVD ROM and is labeled as "DVD Video" Usually replication becomes cost effective in quantities of 1,000 or more. Whichever facility you choose will tell you the best way to get what you need, and will let you know what sort of master file they require- often it is simply an image file (.iso) of your DVD. |
Hey Diana...
Simply save the build out to an ISO image.. Duplication is the way to go for your needs. If you don't have a tower burner, then usually, somebody who does sporting events, or dance recitals should have the equipment to simply duplicate your original ISO image. Usually 10 discs at a time. Each ISO burn on a DVD-R shouldn't take more than 5 minutes. Nothing gets lost in the process. It's a straightforward copy. |
Thank you both!!
Another question.. If I build my DVD as normal in Encore is there anything specific I need to do to make it a Master? |
no, a DVD has no master feature, except if you are looking for protection (CSS encryption).
in that case you need to provide a special master, but it requires a special burner. |
I used to write the software that ran both tower and automated high speed duplicators, included integrated printing, so I know what's needed and what's not ;) I use Encore to make ISO files and send them to duplicators via a network, but I could just as easily make playable discs and read them as masters. |
The duplicators that we use accept a DVD-R to create their glass master. I just post it to them.
An ISO could be used if the files are small enough or you both have fast internet connections. |
