CC 2015 Export clips??? at DVinfo.net
Adobe Creative Suite
Old July 18th, 2017, 07:46 PM   #1
I should know this answer but at the moment I am brain cramping......
When you cut multiple clips in a sequence into multiple clips is there a way to export that sequence and make each cut its own individual clip? In other words, I don't want to make 20 sequences out of the 20 cuts to export them. I think I am missing a way to export them in Premier or to media encoder and keep my cuts as stand alone clips?
Kind Regards,
Steve
www.CorporateShow.com
Old July 18th, 2017, 11:56 PM   #2
Re: CC 2015 Export clips???
If I understand correctly what you want to do there are two possibilities:
make each cut clip on your timeline into a sub-clip,
or
set the work area over each clip on the timeline in turn and export just the work area as a separate clip. That way you can export in a "lossless" codec like Lagarith so your clips can be further processed without degradation.
Alan Craven is offline   Reply With Quote
Old July 19th, 2017, 07:13 AM   #3
Assuming you are on CC latest.
You can cut your clips in the source monitor and make then into subclips.
No need to put them on the timeline.
Select them all in the Project window and hit ctrl+M (export media).
Rest is self explanatorily.
ACE Premiere Pro CC
Adobe Community Professional
Old July 19th, 2017, 06:46 PM   #4
Thank You Alan and Ann! Worked great, I knew there was something I had forgotten!
Steve
Steven Digges is offline   Reply
